configure policy app-signature minimum-ttl
configure policy app-signature minimum-ttl [none | 1 | 5 | 10]
Description
Configures a minimum time-to-live (TTL) value for Layer 7 policy/application signature.
Syntax Description
app-signature Specifies configuring application signature settings.
minimum-ttl Specifies setting override to low DNS-reply TTL values with a minimum value. The default is none, which specifies not overriding the TTL values.
none Specifies not overriding DNS-reply TTL values (default).
1 Specifies a minimum TTL of 1 minute.
5 Specifies a minimum TTL of 5 minutes.
10 Specifies a minimum TTL of 10 minutes.
Default
By default, the DNS-reply TTL values are not overridden (none).
Usage Guidelines
To view the TTL minimum value set by this command, use the show policy app-signature command.
The following example sets a minimum TTL of 5 minutes:
# configure policy app-signature minimum-ttl 5
This command was first available in ExtremeXOS 30.5.
The ExtremeSwitching 5520 series switch does not support Layer 7 policy (DNS).
Platform Availability
